I have been tasked with creation of a PAL DV .mov with ffmpeg matching the following specifications:
I would like to keep the output as close to the specifications above for broadcasting purposes. I created two samples with -format mov -target pal-dv -r pal and -format mov -target dvvideo -r pal, but both files were rejected by Adobe Media Encoder.Code:General Complete name : sample.mov Format : MPEG-4 Format profile : QuickTime Codec ID : qt File size : 2.01 GiB Duration : 1mn 42s Overall bit rate : 167 Mbps Writing library : Apple QuickTime Video ID : 1 Format : YUV Codec ID : 2vuy Duration : 1mn 42s Bit rate mode : Constant Bit rate : 166 Mbps Width : 703 pixels Original width : 720 pixels Height : 576 pixels Display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 25.000 fps Color space : YUV Chroma subsampling : 4:2:2 Compression mode : Lossless Bits/(Pixel*Frame) : 16.387 Stream size : 1.99 GiB (99%) Language : English Color primaries : BT.601 PAL Transfer characteristics : BT.709 Matrix coefficients : BT.601 Audio ID : 2 Format : PCM Format settings, Endianness : Little Format settings, Sign : Signed Codec ID : sowt Duration : 1mn 42s Bit rate mode : Constant Bit rate : 1 536 Kbps Channel count : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Stream size : 18.8 MiB (1%) Language : English Other ID : 3 Type : Time code Format : QuickTime TC Duration : 1mn 42s Time code of first frame : 01:00:00:00 Time code settings : Striped Language : English
That's like saying, "I want to create a SQUARE with these requirements: constant radius from centerpoint (aka CIRCLE)." It's an oxymoron. It cannot be done.
Your "DV" MOV file is not a DV-type file, it is a losslessly-compressed YUV4:2:2 MOV file (of unknown codec). Could be Apple, Aja Kona, Drastic...
You want something more like: -vcodec rawvideo -pix_fmt uyvy422 -vtag 2vuy.
But if you are inputting to AME anyway, why the requirement now? Both are encoders with outputs - why not output what your intended output from AME is supposed to be and bypass 1 generation of encoding? (or do you not have AME yourself?)
BTW, that LPCM audio is backwards-endian for a normal MOV (most normal LPCM MOVs are "twos" Big Endian). Another strangeness in your request.
Scott -
Thank you for responding. -vcodec rawvideo -pix_fmt uyvy422 -vtag 2vuy is exactly what I was looking for, but how do I define the color primaries in the metadata through ffmpeg?
I was loading the files in AME to check for general compatibility. The end product from ffmpeg will not be fed to AME. -
Here are 2 quick places:http://www.ffmpeg.org/faq.html#How-do-I-encode-Xvid-or-DivX-video-with-ffmpeg_003f
and
https://trac.ffmpeg.org/wiki/Encode/MPEG-4
From what I can see, there isn't full documentation on FourCC options, as that is external to ffmpeg (used primarily with AVIs & MOVs).
Not sure about metadata for 601, but I'm guessing that, since your size is SD PAL, 601 is used by default whether it is flagged in metadata or not.
